Thread: DE filter pressure frequently high
    Jul 2007
    Maryland
    89
    My pool was opened for the first time Monday, July 3rd with fresh quartz plaster. I've brushed at 3-4 times a day. My DE filter only lasts about 24 hours at the normal 12psi; so far, I've backwashed 3 times due to high pressure. Is this normal or could the grids be clogged this soon?
    c ya, grivera
    IG, Cement, 18,600 Gal; DE, SWCG, Nature 2; 1.5 hp pump; Quartz Aggregate, Mid-Atlantic-1st opened 7/07
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I'd say normal. DE is very good at filtering, and the fines in a new pool will clog it quickly. Just make sure to add the recommended amount of DE after backwashing.
    Jul 2007
    Maryland
    89
    Coming right along; every 3 to 4 days needing back flush.
    c ya, grivera
    grivera, if you PSI drops back to normal after a backwash and recoat, the grids are not likely clogged.
    Jul 2007
    Maryland
    89
    Thanks Rangeball, good to know.
    c ya, grivera
