Thread: HELP HELP HELP
    Jacksonville Fl.
    21
    HELP HELP HELP
    FC is 12.5....is it safe to swim in the pool? CYA is 25....my wife added 2.5 gallons this morning....so essentially we shocked. Bad part, we have company over to swim!
    rerrrrrrrrrrrrrrrrrrrrrrrreeeerrrrrrrrrrrr
    14000 gallon, AG, Sand Filter and know idea of pump flow rate....
    Jul 2008
    Bucyrus, Ohio
    108
    Re: HELP HELP HELP
    It should be safe as long as you have your filter and pump running to circulate...also it wont last long if your cya is only at 25 with fun sun.
    Overwhelmed
    Pool size: 15' X 48" AG vinyl liner, 5300 gallons, Hayward S166T filter and 1hp pump
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: HELP HELP HELP
    you're at the high end of shock. can't say that it's recommended by most posts I've seen here, though I probably would just because I live on the edge like that, heh.
    I would throw her in first since she screwed it up. if she's ok then let everyone else in.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: HELP HELP HELP
    when are they comming over? If you get full sum, you should be able to come down 2FC by evening...if not you can add some liquid CYA for a quick fix or something like this may be your only option http://www.intheswim.com/Pool-Chemic...e-Neutralizer/
    Re: HELP HELP HELP
    Wear old suits just in case, and I would not let any really small children in... (who might ingest a lot of water)
    The liquid CYA would be a good quick fix... You could stand to bump yours up a bit anyhow!!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
