Results 1 to 11 of 11
Thread: Arman Hammer Baking Soda Tablets..any downside?
    Exton, PA
    250
    Arman Hammer Clear Balance™ Pool Maintenance Tablets
    I have a friend who is using the BBB method and went away for a week. His TA and pH seem to drop fairly regularly, so he tosses one of these Arman Hammer pucks in. He swear they bring his pool into spec within an hour and maintain pretty well.
    They're $25 for 16 tablets at walmart. Fortunately, I have no issues with either pH or TA, but was wondering what you all thought of these tablets (just in case).
    18' AG pool, 7,646 gallons, Sun from 11:30AM-2PM.
    Pentair Dynamo 1hp pump, Intermatic Timer (6/17)
    Pentair Sand dollar filter - 100lbs, 35gpm
    Pentair Lil' Shark cleaner, TF-100 Kit
    Raypak 206A 200K, BTU gas (6/17)
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    12,089
    Re: Arman Hammer Baking Soda Tablets..any downside?
    I hadn't heard it it so I looked it up, looks like it's just their Soda Ash in tablet form, which is convenient to use with trichlor tablets. I couldn't find the MSDS.
    There must be a reason why his PH and TA drop regularly....normal BBB methods they should hold stead, unless his tap water is very low in both and he has alot of water replacement?
    Usually the PH/TA drop with trichlor use and soda ash is the remedy for that...
    It looks to be a slow dissolving baking soda tablet with added clarifier, at least according to this web page. I suppose that if you are using trichlor it might compensate for your PH and TA constantly falling, but even then it would be less expensive to use soda ash, so I don't see the point.
    Exton, PA
    250
    Where can you buy soda ash?
    12,089
    I haven't seen it at my local walmart, but it would be in the laundry aisle. It's also called "PH Up" in pool stores....but for more money, LOL.
    Soda ash is sold as ARM & HAMMER® Super Washing Soda Detergent Booster. Do not confuse this with ARM & HAMMER® laundry detergent! It is sold in the laundry detergent section of most larger grocery stores and some big box stores. It is also sold by pool stores under various names, including pH Increaser, pH Up, Balance Pak 200, etc.
    Tonedeaf's Avatar
    Jun 2008
    East of Dallas
    104
    Soda ash can also be found at craft stores near the fabric dyes. Wife just finished a tie dye project with some family kids and used soda ash to prepare the fabric before dyeing commenced.
    14100 gallon IG Gunite Pool
    Sapphire Smoke Quartz Plaster
    Pentair SunTouch Controller, Intelliflo 4x160 Pump, 520 Cartridge Filter, Intellichlor SWG System
    Legend Platinum Cleaner with booster pump
    My Pool Build
    Loogootee, IN
    122
    arm and hammer pool care stuff at the 3 closest walmarts to me is right next to the "hth" chemical stuff...
    18ft x 48in Round Intex Ultra frame. 6,700 gallons.
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Leslie's in Exton has it also. It is in a small tub and is labeled Soda Ash.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    saw the A&H tabs at my walmart as well in the pool supplies/toy section...$16 or so for a bag of baking soda tabs Got to love marketing
    Here is a link...alomg with a link on the webpage to the official A&H pool care guide...honestly, it seems to give pretty solid advice, but does not mention this clear balance marketing stuff
    Mar 2007
    San Rafael, CA USA
    12,082
    This website lists the ingredients on the label as:
    Sodium Bicarbonate.....86.60%
    Clarifier And Other Ingredients.....13.40%
    Arm & Hammer describes their Clear Balance product in this link where you can read a Pool Owner's Guide which goes into more detail. Basically, the product is just baking soda plus a clarifier. The talk about pH is about pH stability (i.e. buffering). This product would mostly be used with Trichlor to keep the TA higher, though realistically one could use a pH Up product to balance TA and pH at the same time at a not-so-high TA level. If you use baking soda, the TA would have to be quite a bit higher to only use this product to maintain the TA and pH at the same time.
