Results 1 to 12 of 12
Thread: Cooling the water off (please don't laugh)
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Here's my Rube Goldburg aerator. I used a vacuum leaf picker upper attached to my polaris booster pump. Then used duct tape to attach a noodle for flotation. The first try worked too well - it blew water all over the place and I was afraid I would empty the pool. The revision does not work nearly as well, but at least it's not watering the grass.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    Re: Cooling the water off (please don't laugh)
    Wow!
    Feb 2008
    Denton, TX
    5,061
    You might be able to get one of those flow restrictors for the hose at a Home Depot or similar place and place it between the hose and the vaccum head to decrease the flow of water and keep more of it in your pool. Not sure if you have seen them before or not. They are little discs with a small hole in it and you place it in the female end of the hose where the O-ring is and then just screw the hose on like normal.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Macgyver!
    Butterfly's Avatar
    South Carolina
    10,045
    What did we ever do before duct tape?
    You're done SLAMing when:
    Arizona
    924
    Good for you! I love inventive and creative people.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    I found a new location for the fountain - braced against the ladder with the water stream aimed diagonally across the pool. This kept the water in the pool. I let it run all night last night and the water temperature dropped by 12 degrees from 92 to 80 F.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Coolio!
    Make sure you keep watch on your pH. Aeration sure cools the pool, but also causes the pH to rise.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Quote Originally Posted by MikeInTN
    Coolio!
    I was watching for that, but the pH didn't change a bit. It was 7.5 yesterday and 7.5 after running the fountain all night.
    hahaha.... sweet!
    2003 Marquis Euphoria - 400gal
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Great idea -
    I kind of like 92º water. 8) That's because it is 102º outside
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    I would be in trouble with water at 80 degrees. Ha. The wife and kids like it closer to 92 and at times still complain about it being chilly. Myself, I like it closer to 85 degrees.
    Your fountain looks cool. I have a store bought model myself that connects to the return and makes a nice fountain of water with adjustable height. It has a bypass that can adjust to wide open or fully closed depending on how tall you want the fountain to be. My PH rise was not affected much by the fountain after I got all my number right; sounds like your in the same situation. Good job.
    27' round AG vinyl, 54" height with 18,200 gallons of water.
    1HP pump, 150lb sand filter run 12-14 per day. Using 12.5% liquid chlorine. BBB method.
    Taylor K-2006 test kit. Lamotte strips for borate at 50ppm.
    Goals: CYA-40, TA-80, FC-4, CC-0, Borate-50, PH-7.4-7.8 with use of fountain.
