Thread: Cal Hypo
    Cal Hypo
    Hi guys do anyof you here have experience dosing cal hypo tabs via a feeder, iv seen comments that the feeder needs cleaning from time to time if not sludge forms, is this true?
    Can i use a normal Rainbow chlorinator to feed?
    27,500gal IG plaster that needs recoating/painting!, Pentair Whisper-flo 1hp 2 speed, 48sf DE, Pentair Legend II pressure-side cleaner, BBB newbie
    Guest
    Re: Cal Hypo
    Quote Originally Posted by aho.lwi
    yes
    No, you need a vented cal hypo feeder.
    Re: Cal Hypo
    Cal-hypo feeders are very different from trichlor feeders because cal-hypo dissolves so quickly compared to trichlor. You can't use cal-hypo in a trichlor feeder and you can't use trichlor in a cal-hypo feeder.
    Re: Cal Hypo
    SOrry whats the difference from a vented feeder and a standard chlorinator? Please excuse me ima noob on this..
    So what sort of feeders should i be going for ?
    Re: Cal Hypo
    and where can i get them?
    Re: Cal Hypo
    iv got an air bleed valve on my feeder which i can fit an air release valve if thats what you call it, if so can it be used?
    Basically fed up with using TCCA, all the problems it has caused me lately.
