Thread: when to shock
    when to shock
    do i need to shock on a regular basis if test numbers are right and no other problems?
    24 ft. 52 in. deep above ground
    hayward sand filter
    new pool owner/new bbb believer
    Butterfly's Avatar
    South Carolina
    Re: when to shock
    Pool School, link at top right (big white button) has all the info
    Here is the first paragraph from "How to Shock your Pool" from Pool School.
    Shocking the pool will eliminate algae, combined chlorine (CC), and any other organic contamination. If you have algae, or the (CC) level is above 0.5, or the free chlorine (FC) level is zero, you should shock the pool. Many people also like to shock the pool when the FC level falls significantly, as it often does after a major storm or large swim party. This is done even if FC doesn't get all the way to zero, just to be sure everything is all right. If you are maintaining proper FC levels there is no need to shock weekly, or on any other regular schedule.
    Welcome to the forum
    You're done SLAMing when:
