Thread: Another "Is this normal?" question.....re skimmer shloshing
    May 2009
    Ontario, Canada
    84
    Kids are in the pool with friends. My daughter calls me over...There's a ton of water sloshing out of the skimmer basket (outside the pool)... and the pump window housing part...was only about 1/3 full of water. The kids were doing ALOT of jumping around...making waves....It seemed the skimmer basket would suck up all the water (and air I'm assuming), then fill up with too much water....repeating this over and over again.
    I just shut off the pump and turned it back on after the kids were done and the water was calm. Everything seems good again.
    Is this normal?
    21' 54" Round AG, 10K gallons,1HP 2 speed pump, Sand filter 200lb
    Have had a sparkling BBB pool all summer....
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Another "Is this normal?" question.....re skimmer shloshing
    The kids displaced the water above the level of the skimmer. When that happens, a: water comes out the top of it, and b: your skimmer weir can get stuck sticking straight up, allowing the skimmer to pull air. That's what caused the air in the pump.
    Turning the pump off 'til they got out was the right solution.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Your skimmer wier is installed...yes? Sounds like either what spihex said or the weir is missing
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    You did the right thing. Darn kids! I know what you mean though, they can really get those waves going!
    May 2009
    Ontario, Canada
    84
    Yes, the weir got jammed and I had to push it back in ....
    Okay.....thanks!
