Thread: plumbing test pressure
    What is the proper plumbing test pressure and for what duration. I ask because I tested my two skimmers at around 20 psi and the skimmer extension (the female fitting where my piping attaches to) has developed hairline cracks on each skimmer. I will need to pull out each skimmer and replace/re-pipe. The piping that I installed is fine. Is it normal to test the skimmer piping as I did?
    Mark
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: plumbing test pressure
    When I do a pressure test I only go to around 10-15 psi, and then watch to see if the needle drops. if you can see the cracks why not throw some plast-aid on there? It works very well. http://www.plast-aid.com/
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    mas985's Avatar
    Pleasanton, CA
    11,742
    New pools are generally pressure tested to at least 35 PSI. If you know your normal dirty filter pressure, you should at least test to that level if not slightly higher.
    Mark
