Thread: Hayward IG pool light not working
    May 2008
    Ridgewood NJ
    Can I test the unit by inserting a standard incandscent bulb? Last year I pulled the housing and there was water inside. I cleaned it up and now it is not working(I did not replace the gasket as I probably should have). I am waiting for a new gasket to come in but I want to make sure the housing works before I seal it up an put it under water. Thanks
    35,000 gallon IG pool. pebblefina sapphire galaxy finish
    2hp Hayward 2 speed pump, Hayward DE600 grid filter, Hayward Heater, Polaris booster and 280 cleaner
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    Re: Hayward IG pool light not working
    Yes, you can test it with a regular bulb.
