Thread: to spend or not to spend?
    Jul 2008
    smithfield VA
    34
    Hi, I'm back from last year and about ready to set the pool up.
    We have a little intex soft-side, and last year all I did was keep it up with bleach (1000 thanks to this site!). This year I was considering going a little bit bigger, but (and this will be more funny to mommys out there who have "preggo brain" that has lasted a bit longer than expected) the new pool I was considering is 15'x36" and according to my siggy here, the one that is in my shed waiting to be put up is 15'x30", so hardly worth upsizing (although I could have sworn that last year's pool was only about 12' across...).
    ANYWAY.
    new pool or no, I need a much bigger pump and filter. The one that came with the pool and I used last year just didn't work. So I'm thinking of a salt water system.
    I see on ebay a SWG with 2000gph pump/filter for $279. That much pump is probably overkill for my little pool, yes?
    However, to buy it separately, it's $169 for the SWG and then either $45 for a 1000gph pump or $90 for a 1500gph pump.
    SO- Do I just buy a bigger filter pump and continue with my bleach routine from last year? Or do I spring for the SWG/Pump and figure I may someday get a bigger pool and need the extra firepower?
    *I really have no desire to go over 30-36" because of the ages/sizes of my kids, so a bigger pool is not really something I forsee anytime soon.
    proseries Metal frame, 26 x 52 -purchased, installing soon
    Re: to spend or not to spend?
    Long term you are going to want a better filter than any of the Intex filters. You might not be able to afford it right now, but you will want it eventually. Because of that, I see a significant advantage to getting a SWG that is separate, and is not integrated with the pump/filter. A separate SWG will work with the future filter, and it doesn't seem to cost you anything extra right now to get a separate one, so that seems like a simple choice to me.
    Jul 2008
    smithfield VA
    34
    thanks Jason. I just found a few old threads about the intex SWG and it seems like even with mixed reviews it would be worth getting and be a peice of equipment that would "graduate" up to larger pools.
    So quick last question... for the 15'x30" pool, what size filter pump? I think the awful little thing I had last year was the 530gph model. Is the 1000gph ok for the approx 3000 gal capacity of this pool?
    Yes, the 1000 gph pump should be fine.
    Jul 2008
    smithfield VA
    34
    awesome, ordering now! I hadn't thought about the disadvantages of having the combo swg/filterpump, so thanks again for pointing that out to me!
