Thread: question about CYA
    May 2009
    Ontario, Canada
    84
    question about CYA
    If I have what I think is alot of direct sunlight...from 12 to 8pm (canadian climate though)...what should my CYA target be....
    As of now I have been putting 30 as my goal...and have added 1Kg of stabilizer to the pool.
    21' 54" Round AG, 10K gallons,1HP 2 speed pump, Sand filter 200lb
    Have had a sparkling BBB pool all summer....
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: question about CYA
    30-50 is the recommendation. keep going until you find what works for you. I doubt you'll want more than 50.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Usually we recommend 50 at the start of a season for a sand filter, as backwashing will slowly drop your level. Not sure how much longer you have in the summer, but 40-50 will be fine.
    Guest
    30 is the minimum level.
    Whenever there is a range like 30-50 shoot for the middle as a rule of thumb.
    May 2009
    Ontario, Canada
    84
    Thankyou, I will shoot for 40
    Thankyou for all your help. I would be lost right now without this forum.
