Thread: Input on replacing pump in above ground pool?
    I've got a several year old Doughboy 21' AG. I recently replumbed it with PVC as I was constantly fighting with leaky flex lines. I went ahead and replaced my filter sand at the same time. I think I damaged my pump though while moving stuff around, as it now is leaking. It's a Doughboy Power Pak II, 1HP. I replaced the motor a couple of years ago when it died, but I'm now wondering if it's wasteful to throw more money at keeping this pump alive. I have found at least two cracks - both in the basket canister. It looks like I can get a replacement canister for ~$120. If I was confident that this is the only problem, I'd be fine with this, but I don't want to replace this part only to discover that the leak was elsewhere. Part of why I think there may be a leak in the body of the pump is that it leaks worse while running.
    So, do I continue to keep this one alive by throwing parts at it, or do I go ahead and replace it? If I replace it, with what? It seems that 1HP pumps range from $200 - $1200, and not being in the industry, I have no knowledge on why.
    FYI, this pump has been serving us fine, so I don't think I need any more power, flow, or features. It's a 110V unit that simply plugs into a grounded outlet, and I'd prefer to keep it that way (no hardwiring, timers, etc.)
    Thoughts?
    Thanks for your input.
    Re: Input on replacing pump in above ground pool?
    Welcome to TFP!
    An above ground pool pump shouldn't be all that expensive, perhaps $200 to $250. In-ground pumps tend to be much more expensive.
    hey i just got a waterways brand 2 hp pujmp brand new off ebay for 154 with 25 dallar shipping ... he also had a buy in now on a hayward 1.5 hp for 179 .... my 2 hp is way over doing it i know but my 5500 gallon soft side never looked so clean hehe ... just call me tim the tool man har har har
    Since it's still working, I think I would just start watching craigs list. I bought my Hayward 3/4 hp pump, and Pentair sand filter for $100. I have saw several used pumps for sale cheap.
    Sharkline Matrix 15' x 30' x 54" Oval, Pentair Clean & Clear 150 sq. ft. Cartridge Filter, 1-1/2 HP OptiFlo Dual speed Pump, TF-100 test kit, borates
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I would shop around, and try to find a 1.5 HP- 2 speed, that you can run on low speed for the elec savings. The savings alone would pay for a replacement pump in a few short years.
