chemical content of European swimming pool products
Hi
I found this page, looking for the CYA content of the chlorine tabs I bought in France:
http://ile-de-france.sante.gouv.fr/santenv/legion/prodpis.htm
Trouble is, I don't fully understand the numbers.
NOM DATE SOCIETE CL2 PRODUIT AGR
CARREFOUR CHLORE PASTILLES 50/20 02/11/94 ELF - ATOCHEM 50 ACIDE TRICHLORO-ISOCYANURIQUE 1934
So Cl2 = 50 and trichloroisocyanuric acid (C3Cl3N3O3) =1934, but what? milligram? The tablets weigh 20 gram each, so they are 99% something else? That can't be true.
It probably is a relative number, independent of tablet weight. Also, the chlorine content varies with the same AGR (?) value. The Wikipedia entry of trichloroisocyanuric acid is probably written by a pool-chemicals salesman:
Benefits of TCCA in Swimming Pool- [sic]
* Available with 90% chlorine concentration
* Due to high chlorine content, handling is easy for large pools.
http://en.wikipedia.org/wiki/Trichloroisocyanuric_acid
Can somebody explain to me how the chlorine concentration can vary in a pure substance with a known formula? :shock:
Or is this just more obfuscation from pool-chemical sellers?
I'm so happy I found TFP. I was wading through all kinds of stuff and outraged by the prices. Solid info was nowhere to be found. I'm still attending Pool School.
Not knowing french, it is a little bit difficult to be sure, but those appear to be 55% trichlor and 45% filler. Pure trichlor has 90% available chlorine, but these have only 50% available chlorine, so they are 55% trichlor and the rest is inert.
The way things like % available chlorine is calculated is weird, it is easy for the percentages to add up to more than 100%. If you really want to know, read here, but I don't recommend trying to understand it.
