Thread: Should I use some sort of Ant "Barrier" ??
    pool4me's Avatar
    Sep 2008
    Bucks County, PA
    As I get ready to do the pool base, I'm wondering what others have used (or did not use) to tread the ground to prevent ants under the pool?
    I've used appx 6" of screenings / road base for the site of my pool (very rocky soil).
    It really packs like concrete but still I"m thinking I should use some sort of barrier / chemical to help prevent bugs / ants.
    Any suggestions?
    33'x15' x 52" Aqualeader
    Gallons ? - (I use appx 13,500 to calculate "stuff")
    33 x 15 x 4.3 x 5.9 = 12,558. or . . The Pool Calculator = 14,400
    Hayward S-166T 100Lb Sand Filter - Hayward Power-Flo LX 1HP Pump
    Intex S.W.G.
    Sep 2008
    The Woodlands, Texas, USA
    Re: Should I use some sort of Ant "Barrier" ??
    I don't think anything is needed.
    If you did put something down getting it to last years (thinking chemicals) is difficult.
    One of the longest acting are the termite treatment chemicals which also kill ants.
    I would probably not put plastic down because drainage is good in general and where there is moisture retained there ye will have bugs also.
    IG 24k plaster with overflow spa. Goldline PS-8 SWG. Tristar 0.75 HP filter pump, Polaris 280, large cartridge filter, 400k BTU NG Max-E-Therm HD, SR Smith Turbo Twister, Life Saver pool fence, ORP managed.
