Thread: Inconsistent Return Flow (super newbie)
    Pittsburgh, Pennsylvania
    2
    Won't go into details here, but I have moved into a house with a long ignored in-ground swimming pool. Last year I got it cleaned just in time to close it last year, opened it up this year, and it's time to fine tune...
    Now I am finding that there are several fine tuning type problems, and I'm not even really sure where to begin. Figure I have to start somewhere so why not here. There is only one return into the pool. It is shooting out really inconsistently. I shot a video to try and capture what's happening but it's kind of hard to tell. Perhaps take a look...
    [youtube:2frnui9i]Qz_g_mpPOkU[/youtube:2frnui9i]
    As you can see there are quite a few air bubbles coming to the surface. Not all the time though, just every few seconds. I know this is not a lot of info to go on, but if anyone has any suggestions please feel free to chime in.
    Thanks in advance for any help anyone can give, and I plan on spending a whole lot of time here this summer, so please be patient with a guy who is in way over his head.
    THANKS!
    MY INFO:
    16'x32' abt. 23,000 gallons
    IG, Vinyl Liner
    Cartridge Filter
    1 HP Pump
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Inconsistent Return Flow (super newbie)
    If there is air in the pump basket, then you might have an air leak in the suction side plumbing. Air will build up in the filter and then exit the returns. Air leaks are usually casued by the pump basket lid not sealing properly or the drain plugs not sealed properly.
    Mark
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    there is a good article on leak detection in pool school. see paragraph 3 under the leak detection article. it should help you find where that air is coming in from.
    pool-school/
    2
    Thanks for the tips all. I spent the rest of the afternoon out at the pool so I didn't have a chance to look itoyour suggestions; will do so tonight. Here's hoping...
    MY INFO:
    IG, Vinyl Liner
    Cartridge Filter
    1 HP Pump
