Thread: Our Hayward SwimPro Pump keeps shutting off...
    I went out Tuesday morning and the pump was running, but no water was moving. My Dad came and the impeller/propeller whatever was broken, so he replaced that and the seals. Now it sounds like there is air in it - but there isn't that we can find, and it keeps shutting off by itself. (and it's not the timer/programmer).
    Any ideas?? Short of having to buy a new pump!
    21x41x54" AG Artesian Seville II
    Installed around 2004 - we moved here in 2008
    23,000 gal
    Hayward SwimPro 256T Sand Filter
    1HP 2speed Hayward Power Flo Matrix
    (and have 2HP Hayward Swimpro and a 2hp 2speed Waterway Hi-Flo pump as back up also!! lol)
    No heating - other than Solar SunRings
    Central IL
    ekosanke's Avatar
    Jul 2009
    Sherman, TX
    Re: Our Hayward SwimPro Pump keeps shutting off...
    Is it circulating water? How long did it run without any water flowing? Were the bearings replaced in the pump? Most likely it is thermal protection shutting it down. It probably restarts normally after it cools off.
    You might try disconnecting the the motor from the pump and letting it run. Does it shut off then? -ed
    [center:2odzq454]25000gal Hayward Sand Filter InGround Plaster 1.5HP Century[/center:2odzq454]
