Thread: Solar Blanket w/ A-Frame Ladder
    When using a solar blanket in an above ground pool with an A-frame ladder, should a small rectangular section be cut out of the blanket allowing it to fit around the ladder without bunching up? Thanks in advance.
    11000 gallon Viking Fiberglass 12 x 28, Intellichlor IC-40 SWG, 24" cascade fountain, 12" cascade fountain, 1 1/2 HP pump, sand filter
    Jan 2009
    Cupertino, CA
    Re: Solar Blanket w/ A-Frame Ladder
    Yes. You want the solar cover flat on the water, so the wind is less likely to catch it. Just cut to fit.
    BBB "Intermediate Swimmer"
