Thread: Dual Filters
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    Dual Filters
    We have are currently running a 1 HP Hayward Power-Flo LX pump and 100# Jacuzzi sand filter. I have the option to buy another Jacuzzi 100# Sand filter at a low price(used)(exact same model as the one I have now). I know that the bigger the filter the better(to a point) and I'm pretty sure this filter is too small for the pump(Is this assumption correct?) My thought was to tee off the pump outlet and run the two filters in parallel sitting next to each other then Tee back together on the other side.
    This would give me double the filtering area(more area than a 200# filter, right????) and half the GPM flowing through each unit, while also reducing Head pressure and increasing overall system performance. The filters would both dirty equally because the pressures would want to balance(water takes the path of least resistance).
    Also, yes I know Jacuzzi is out of business, but if anything I can use the second one for parts if one breaks.
    What do you all think???
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    frankthailand's Avatar
    Apr 2008
    Re: Dual Filters
    Can't see any probs there, that will be fine maybe a couple of valves so you can backwash onne at a time.
    Happy swims
    Hello all from the land of smiles. Thailand. 5mx9mx1.5 63000L 16300 gall, pebbletex,
    pentair 1hp whisperflow, tagelus TA60 SF, swg monarch esc24 {a bit small for the tropics} 3 returns, 1 skimmer, 2 astral 100watt lights. Planned and built by me
    an AUSSIE expat living thailand for 18 years.
