Results 1 to 7 of 7
Thread: Diluted CYA and Salt & Leak
    Jul 2008
    Seacoast, NH
    250
    It has been raining here for about 3 weeks straight. (Sigh) My CYA and Salt have been diluted.
    I also have a leak. I think it is in the filter system because, when the filter is off (has been off for hours) I can hear bubbles going through the filter.
    While I wait for the PB to come fix the leak, is it worth putting in more salt and CYA or should I wait until after it is fixed?
    FC = 5
    CC = 0
    pH = 7.4
    TA = 120
    CH = 170
    CYA = 45
    Salt = 2890
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    Re: Diluted CYA and Salt & Leak
    The numbers look fine to me. I would wait until the repair is completed, run the full test set, then decide if you need to make a change.
    CYA of 45 is a good number.
    27' round AG vinyl, 54" height with 18,200 gallons of water.
    1HP pump, 150lb sand filter run 12-14 per day. Using 12.5% liquid chlorine. BBB method.
    Taylor K-2006 test kit. Lamotte strips for borate at 50ppm.
    Goals: CYA-40, TA-80, FC-4, CC-0, Borate-50, PH-7.4-7.8 with use of fountain.
    30,419
    How much water are you losing each day?
    Jul 2008
    Seacoast, NH
    250
    It's difficult to tell how much we are losing because it has done nothing but rain for the last 3 weeks. However, even with all the rain, the water level has not gone up. Before it started to rain, we measured and it looked like we were losing an inch a day with the solar cover on.
    1.5 HP Pump
    30,419
    How long before your PB is coming out to find the leak?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by gsmornot
    45 is too low for an SWG user.
    Jul 2008
    Seacoast, NH
    250
    PB is suppose to come this week.
    I added salt because I had it and it's cheap. I'm having no trouble keeping the Chlorine up so I may leave the CYA until it's fixed.
    I'm very worried that the leak is under the concrete deck. I don't see bubbles in the pool and I don't see any puddles under anything above ground.
    1.5 HP Pump
