Thread: Low speed pump=Filter 0
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    The electrician was here sometime today and got my pump wired so I could use the low speed. I don't think he could figure out how to wire it in to the Pro Logic the first time When I put it on low my filter pressure gage goes to 0. Is that normal?? I can hear water gurgling in the filter. It seems it's just one thing after another
    Thanks
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Low speed pump=Filter 0
    Pressure should be about 1/4 of high speed but the gauge may lose accuracy at low pressure so it may look like 0 but actually be a few PSI.
    Mark
    With the pump on low speed the filter pressure can be zero, or one or two, something quite low in any case. You should be able to feel flow at the returns.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Yes, I have quite good flow at the returns, so is everything o.k.
    Lynn
