Results 1 to 16 of 16
Thread: Heading out of town, what do I need to do?
    Spring Hill, Kansas
    16
    Greetings and thanks for all the info that I have read thus far on TFP.
    The whole family is heading out of town next week for 4 days and we will have no one to monitor our pool while we are away. My question is, since the weather here in eastern Kansas has been scorching for the past week (water temps ~92 degrees) and I am loosing about 4 ppm of chlorine a day. What should I do to maintain our pool while we are away? The good news is that the temps are supposed to drop into the low-mid 80's while we are away, so loss of FC should be a bit less than it is currently.
    Current readings with 11000 gallon fiberglass pool with SWG:
    FC - 6
    CC - 0
    pH - 7.5
    TA - 90
    CH - 250
    CYA - 70
    Salt - 3800
    Last year as new pool owners, we went away for 7 days and left the SWG running at 60% 24 hours a day and when we got back, the whole pool was out of whack. It took me almost a week to get my water balanced to normal. (And since then I have become a bit obsessive on maintaining the pool, it's almost an addiction )
    Now that I have a handle on the pool this year (outside of direct sun, high temps and FC loss of 4 ppm/day), should I just shock my pool the night before we leave to a level of say 20 ppm and run the SWG at my normal 60%? The way I figure, at -4 ppm a day, by the time I get home it will be ready to shock again.
    Ideas, am I on the right track?
    11000 gallon Viking Fiberglass 12 x 28, Intellichlor IC-40 SWG, 24" cascade fountain, 12" cascade fountain, 1 1/2 HP pump, sand filter
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Heading out of town, what do I need to do?
    If you have a cover you could put it on and that will reduce you chlorine loss during the day as well .You could shock it and hope it stays clear until you get back. No reason why it shouldnt ....
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Jan 2009
    Cupertino, CA
    1,966
    The FC loss is better thought of as a rate (% of FC) than a total (4ppm). So, if you bring it up to 20, the first day you will lose more than the usual 4.
    But the whole point of an SWG is to maintain FC on its own; are you having to add 4ppm bleach per day on top of what the SWG produces? That doesn't sound right.
    --paulr
    BBB "Intermediate Swimmer"
    Butterfly's Avatar
    South Carolina
    10,045
    Your test #'s look good and I also can't understand why, having a SWG, you would need to add chlorine.
    Have you done an overnight test?
    It would be helpful if you listed your pool and equipment specs in your sig.
    Go to User Control Panel (upper left under TFP logo) and select Profile, then Edit Sig.
    Welcome to the forum
    You're done SLAMing when:
    Spring Hill, Kansas
    16
    Quote Originally Posted by PaulR
    --paulr
    Paul, if I am at 5 to 6 ppm chlorine one day, I might have to boost it up with about a gallon of 6% bleach every two days or so. But this has only been for the past 7 days or so as we have been having 95+ degree day time temps. Does heat degrade FC, is it just direct sunlight or a combination of both?
    Quote Originally Posted by butterlfly
    Butterfly, I did an overnight test a few nights ago but since my FC was over 5 ppm I couldn't exactly gauge the exact reading. Now that the sun is down, I'll shut off the pump and take another reading. I might have to dilute the water sample since I just added bleach a few hours ago. I'll post back in the morning the results of the FC test.
    Thanks all,
    Chris
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by saunterer
    Both. A heat wave would explain the extra loss.
    If the weather is supposed to break, then shocking just before you leave will probably work out (getting back to the original question).
    --paulr
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    When you get back you should get an FAS-DPD test, it sounds like you don't have that in your kit. It's essential for detecting an overnight FC loss. You can just get that test, to supplement your kit.
    have a nice vacation....
    Spring Hill, Kansas
    16
    Quote Originally Posted by frustratedpoolmom
    I did the overnight test last night. Started at 6 ppm FC and this morning at 0700 it was still 6 ppm. I diluted my pool sample with distilled water at a 50/50 ratio to get this.
    So I guess I'll just chalk this up to the heat wave. Cold front is supposed to move in early this evening. Woo Hoo! I would be nice to swim in 82 to 85 degree water again.
    Gratuitous pool shot It's hard to take a vacation when you have a pool at home.
    30,421
    It sounds like you did the overnite loss test with an OTO kit. It will not be accurate enough to tell you what you need to know. IMO, I use OTO to tell me I have some chlorine in the pool. I use FAS/DPD when I ever need to know how much
    BTW, that's a pretty pool and your water looks very nice and clear.
    11,969
    Gorgeous!
    Spring Hill, Kansas
    16
    I'm using a Taylor DPD test kit from Leslies. I tried those OTO's before an never liked the results. But yes, the pool is crystal clear and sparkling, I just want it that way when get back home on Friday.
    OT: From Raleigh huh? I grew up down in Duplin County and my father now lives near Newton Grove. Need to get back soon for my sweet tea and BBQ fix. Kansas City has good BBQ, but nothing like back home.
    11,969
    Well, the FAS-DPD test is even more accurate than the DPD test. No color matching. You count the drops looking for color change - it's can be done to a .2 precision...
    I highly recommend it.
    Arizona
    924
    What a lovely pool! Looks sort of like a violin.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Spring Hill, Kansas
    16
    Heh. You know what, it actually does. I never looked at it that way.
    Spring Hill, Kansas
    16
    Update.
    Got home last night from a great time in Las Vegas and the Grand Canyon.
    The night before we left, I added a gallon of 6% bleach bringing my FC up to about 14 ppm and bumped my SWG up to 40%, leaving the pump on 24hrs/day. When I tested last night my FC levels were around 8 PPM. Woo Hoo. Now all I have to do today is vacuum the pool, smoke some ribs and watch the kids have a great 4th of July.
    Thanks TFP!
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Welcome home !!
    Glad you had a great vacaton and came back to a clear pool !
    Happy 4th
    Les
    Helpful Links:
