Become a TFP Supporter Pool School
Thread: Pool Pilot - Purifier Off Message
    Jun 2007
    37
    Just installed my Pool Pilot Digital with the SC-48 cell today. Everything seems to check out except I am getting the following message:
    "Purifier Off"
    The unit says I need to add 234 lbs of salt.
    The unit is not giving me a Low Flow message.
    Is something wrong or is this just because of my low salt levels.
    Mark
    Priscilla
    16x32 inground vinyl, 15,000gal, sand filter
    Senior Member JasonLion's Avatar
    37,891
    The "Purifier off! Add Salt XXX lbs." message means that there isn't enough salt in the water for the cell to work. If you add salt it should start working.
    TFP Admin. Creator of PoolMath and Pool Calculator. Other handy links: Support this site, TF Test Kits, Pool School
    Jun 2007
    37
    Thanks. I added the salt, very impressive unit. I have it running my pump also. Way better than my old analog clock timer.
    Priscilla
    Jun 2007
    37
    Now it says purifier on. Yeah! It is already reading 3400 PPM of salt, which surprises me. I thought it would take a couple of days.
    Priscilla
