Thread: Pump Placement
    Russellville, Arkansas
    4
    Pump Placement
    Good afternoon! I will have my 27' AG installed in the next two weeks. All the info seems to indicate the pump/filter needs to be on the low side of the pool. Is there a reason I can't put it on the high side (landscape wise) other than run-off from back-flushing (which I will construct drainage for). Thanks!
    AG Miramar 27'x54" (Not yet installed).
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Re: Pump Placement
    you can put it on the high side if you get inground pump equip...otherwise abg pool pumps are not self priming and should be below water level
    Re: Pump Placement
    The top of the filter needs to be lower than the water level, anywhere that is true is fine.
    Arizona
    924
    Re: Pump Placement
    Jason, do you mean the top of the pump? I don't believe I've ever seen a filter as you describe.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Re: Pump Placement
    I mean whatever is highest. All of the pump/filter needs to be below water level. Usually the highest point on the equipment is the top of the filter.
