Thread: Need recomendation for a Timer
    Huntsville, AL
    Newbe here and the pool should be installed next week
    Curious as to what type of timer I should purchase for the pump.
    I went to one of the Box stores today and there was nothing.
    any help would be appreciated.
    15' x 30' Beachland AG Pool (12000 gal.)
    Hayward 1 HP Power-Flo LX Pump
    Hayward 18" Sand Filtration System
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    Re: Need recomendation for a Timer
    I bought mine from Home Depot. Its just an outdoor timer that has a little door thing on it that opens and closes.
    18ft. Arcadia Round AGP - 19" Sand Filter, 1 hp pump
    Foam cove/ Gorilla Pad/ Wedding cake steps
    Sta Rite Lil' Shark cleaner and Aquabot Pool Rover cleaner - Aqua-Luminator light and return flow w/fountain attachment
    Added Borates 5/19/09 Taylor K-1005 and Taylor FAS-DPD Chlorine Tests
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    the famous ones are made by intermatic. I use a tightwatt.
    Round Rock, TX
    do a search on timers, there are lots of posts about them and lots of comments.
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Jun 2008
    Savannah, GA
    Intermatic timers suitable for pools are often sold in the box stores (HD and Lowes) as hot water heater timers. The only thing relevant is the voltage and amp ratings. If you have a 220V pump, your timer needs to be 220V and an Amp rating that matches or exceeds your pump. Many pool stores sell the same timers as well.
    Here is picture.
    18,000 gal IG plaster Hayward S244T sand filter Pentair Challenger Pump CHII-N1-1FE
    Goldline SWG
    Polaris 280
