Thread: Difference between ABG and In-groung cartridge filters?
    Oct 2008
    Bedford, TX
    31
    Is there a difference between ABG and In-groung cartridge filters. Searched the site and couldn't find info. Looking at some for a ABG pool.
    12x24 AGP, 10k, 1 hp 2 speed Waterway pump, Hayward C900 Cartridge filter, Polaris 65, maintained by Walmart's 6% Bleach.
    Guest
    Re: Difference between ABG and In-groung cartridge filters?
    In a word, no.
    Oct 2008
    Bedford, TX
    31
    I kinda thought that ,but all the material you read about says in-ground, above ground, or both when they list application. Seems to me, how does the filter know the difference?
    Thanks so much.
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    There is not so much difference in the filters, as in the pumps. IG pumps are designed to be self-priming and AG are not. Normally in an IG pool, the pump sits above the water level and if it loses "prime" (water in the pump and basket) will pull water out of the pool with out you having to add water to the pump. In a AG the pump sits below water level and the pump should never loose prime at water is alway there.
    Mike
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
