Thread: Initial #'s - just received my TF100
    Montare67's Avatar
    May 2009
    Naples, FL
    25
    Pool phase of the project is done.
    Excavation started 5/18, plaster on 6/17 and topped of the water and start up chemicals 6/19.
    So happy with decision to purchase TF100 - fast shipping, accurate, easy to use!
    FC - 1.5
    CC - 0
    pH - 7.9
    TA - 70
    CH - 150
    CYA - 30
    Temp 74
    Not sure what I should tackle first - FC, PH, CH..... Like I said -plaster is a week old and I want to start out right.
    Thanks all
    24000gal IG Plaster, Jandy 2Hp, Jandy CL460 Cartridge, Polaris 280 w/booster
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Re: Initial #'s - just received my TF100
    welcome to TFP neighbor...tackle you PH first...drop it to 7.4. Then raise your FC to a minimum of 3, but you can target 5ppm. otherwise your nums look great...if you get alot of sun or using a SWG, you may need to adjust CYA upward and adjust FC accordingly, but your in good shape....just adjust PH first and get some chlorine in there...we don;t want algae
    Chlorine should almost always come first. You should never allow the FC level to go below 2. You should add enough chlorine so that FC is 2 or higher the next day.
    If your plaster is less than one month old, you should lower your PH to around 7.2 and ignore your CH level until the plaster is one month old.
    If your plaster is more than one month old, you should only lower your PH to between 7.6 and 7.8 until you can get your CH level up.
    Montare67's Avatar
    May 2009
    Naples, FL
    25
    Off to pickup bleach and muratic acid....
    Pool contractor told me to stop by their store with a water sample today or tomorrow. May just do it to hear their 'advice' They have some sort of electronic tester that uses pre-measured vials that seems to interpret the color changes. Would like to see what #'s it gives......
    Thanks again!
    Eric
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    LOL, I used to do that for fun if I was bored....
