Thread: First pool water fill test
    May 2009
    Ontario, Canada
    84
    So my pool is almost full to the skimmer. tomorrow we will install the skimmer and the hopefully our get our pump and filter running.
    I tested my water as follows
    Ph between 7.4-7.6
    TA 225
    FC 0.2
    CC 0.8
    CH 130
    CYA haven't added yet
    I was really surprised by the FC and CC thinking that since I had not added anything yet there should be no chlorine. Does this sound right?
    Should I add anything to the pool tonight even though we don't have a pump and filter hooked up yet?
    thankyou
    21' 54" Round AG, 10K gallons,1HP 2 speed pump, Sand filter 200lb
    Have had a sparkling BBB pool all summer....
    Jan 2009
    Cupertino, CA
    1,966
    Re: First pool water fill test
    If it's municipal water, rather than a well, then small amounts of chlorine are typical.
    You probably want to wait until the pump is hooked up before you start adding anything, unless it takes more than a day or so.
    --paulr
    BBB "Intermediate Swimmer"
    May 2009
    Ontario, Canada
    84
    k, thanks
    Mine sat for about a week before I had power out to the pump due to weather. You will be fine on the water if your just going a few days before connecting everything.
    27' round AG vinyl, 54" height with 18,200 gallons of water.
    1HP pump, 150lb sand filter run 12-14 per day. Using 12.5% liquid chlorine. BBB method.
    Taylor K-2006 test kit. Lamotte strips for borate at 50ppm.
    Goals: CYA-40, TA-80, FC-4, CC-0, Borate-50, PH-7.4-7.8 with use of fountain.
