Thread: solar reel cover set up
    Jul 2007
    Michigan,
    18
    Hi what form of solar cover reel set up do you all have,over your pool
    Regards David
    14500 gl, oval, vinyl
    98xc600's Avatar
    Jul 2007
    Southern MN
    148
    Re: solar reel cover set up
    This is my set up.
    16' by 32' cornelius AG vinyl liner, 6' deep end, 14500 gal.
    Hayward 250 Lb sand filter
    Hayward 40 GPM pump
    2-2' by 20' sun grabber solar heater.
    4 gal Liquidator. BBB
    Mine is 1 foot off the far end of the pool 30 feet wide for a 30 foot pool - the reel is made form a 4" diameter aluminum irrigation pipe all custom fabbed.
    May 2008
    Virginia Beach, VA
    84
    Here is ours.
    With a Grecian shaped pool, we have to inset the reel to the edge of the rectangle, and adjust the cover straps accordingly. Kind of a pain, but it mostly works ok.
    28K IG Vinyl lined pool - 1 skimmer, 2 returns
    Hayward DE 60sqft filter; Polaris 280 vacuum with booster pump
    Jul 2007
    Michigan,
    18
    Thanks for the pics. I will be buying a whole new cover and attachments and wanted to try and place the new cover in a way that I could have it outside the pool and not when I roll it up alongside the pool edge[attachment=11bny2wx]IMG_0656.JPG[/attachment1bny2wx]
    this shows it along edge of pool
    [attachment=01bny2wx]IMG_0661.JPG[/attachment1bny2wx]
    this shows when it swiveled round into it's rolled up position
    Regards David
