Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Newbie with too high CYA
    Dallas, TX
    19
    First of all I want to say thank goodness for this wonderful sight. I bought a good test kit and now my pool water has that "sparkle" to it. I plan on draining my pool water this weekend to bring down my CYA and CH.
    My CL test results look like a roller coaster throughout the day.
    6/20
    8AM: added 182 oz bleach and ran pump all day
    10AM: CL was 14.5
    2PM: CL was 10
    5PM: CL was 14 (I tested twice to verify the number)
    6/23
    9PM: added 182 oz bleach and ran pump for 3 hours
    6/24
    7AM: CL was 11
    Noon: CL was 9.5
    10PM: CL was 10
    6/25
    7AM: CL was 10.5
    I was wondering if I'm using too much DPD powder or not enough causing my CL numbers to go up throughout the day. Why would this be happening? Does this happen to all rookies?
    Current test results:
    CL: 10.5
    PH: 7.5
    TA: 110
    CH: 460
    CYA: 120 (guesstimate)
    My wife looks at me like I'm crazy for dumping bleach in the pool.
    Jason M.
    BBB since 6/11/09
    ~19K gal IG;60 sqft DE Filter; Pebbletech
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Newbie with too high CYA
    Hi and welcome.
    What test kit did you get?
    I would advise to save your kit reagents until after you have drained/refilled to get your CYA level lower - right now you are just kinda wasting your time and money and energy. Sorry to have to say that.
    You want to drain about 50% of your pool water to get it to a manageble level. After you do that, recirculate the water for a few hours and then post a new set of results and we'll help you get straight.
    You can't drain before the weekend?
    Dallas, TX
    19
    I'd feel more comfortable draining my pool if I was home and I just don't have time for that until this weekend.
    I'll let you know how it goes.
    Jason M.
    BBB since 6/11/09
    11,969
    I understand. Okay, good luck!
    Dallas, TX
    19
    Can my CYA reading possibly be right?
    I drained what I felt like was about half my pool, filled it up and ran the pump for 1 hour then tested CYA and it was still over 100. I then performed the dilution test by using 5ml of pool water, 5ml of reagent and 10 ml of distilled water then doubled the reading and it showed my CYA was about 130 which is what it was before I drained my pool when I performed the exact same test.
    I thought my CYA problem would be between 60 and 70 after I refilled it. I can't imaging how much it cost me to fill up 8,000-10,000 gallons and see no change in CYA. Surely it would be less expensive to maintain a higher FC level then to drain another 8-10 thousand gallons.
    Thoughts, suggestions, advice, or experience with the same issue??
    Jason M.
    BBB since 6/11/09
    11,969
    Unfortunately, it is not uncommon to hear this unpleasant news.
    The common tests only go up to 100. So anything higher, tests as 100. Dilution loses some accuracy. I think I also read that the CYA can be imbedded in some types of plaster, and redistribute into solution even after significant draining....or something to that effect.
    You may have the initial expense of water replacement, but no I think over time, it works out to be less than trying to run with higher FC levels.
    It's a personal decision, you can try it for awhile and see if you are successful. I'd recommend you add a weekly dose of Polyquat 60 algaecide (not cheap) as a preventative if you do.
    Dallas, TX
    19
    Every post I have read on this sight has me convinced that a low CYA reading is the way to go so I'm willing try it again. After all, I will be saving money by not using my Nature2 cartridge anymore.
    How far off will my TA, PH and CH be after adding all this new water?
    Jason M.
    BBB since 6/11/09
    11,969
    The only way to know is to test the tap water.
    Dallas, TX
    19
    How hard is it on my equipment to have it running on backwash for 2 hours to drain the water?
    Jason M.
    BBB since 6/11/09
    11,969
    I thought I read recently to drain on waste, not backwash. I could be wrong, I'll see if I can find the post.
    Dallas, TX
    19
    I would love to see the post. I'm not sure how to drain it any other way. My backwash goes into the city sewar if that's what you mean by drain to waste.
    Jason M.
    BBB since 6/11/09
    11,969
    Well, I have a cart filter and can't do either.... so bear with me. I assume the multiport valves have filter, backwash, waste, or similar settings. Your valve doesn't have a "waste" setting? This bypasses the filter entirely....
    11,969
    Here's the post I'm remembering:
    Definitely waste. The waste setting moves the water more quickly. Also, on backwash, all of the water goes through the sand filter backwards. Any dirt in the water being pumped out would go back into the pool as soon as the system was put back to filter mode. Using backwash wouldn't be a huge problem, just not as efficient and messier.
    Dallas, TX
    19
    I have the multiport valve (pull up to back wash) and I don't think I have an option to bypass the filter.
    Jason M.
    BBB since 6/11/09
    11,969
    Oh. Sorry, not sure what else to suggest. Maybe someone more familiar with your type of setup will offer up some advice.
    I went through the same problem. My CYA was well over 200 with years of puck use. I only use liquid chlorine now and my pool has never looked better. My CYA now is around 70. It takes alot of draining to get your CYA level down and yours seems to be pretty high. Instead of backwashing through sand filter, I did a drain/refill at the same time by buying a cheap 50 dollar pump at harware store and placed it at the top step. I matched the flowrates of the pump and fill hose and let it run for about 24 hours, keeping an eye on the pool level which stayed abount the same with the matched flow rates. You use more water this way but is much easier. Good luck
    Pool Size 10,000 gallons
    Sand Filter
    In Ground "Pebble Tech" (plaster)
    Dallas, TX
    19
    I drained a refilled again and retested after 4 hours of pump running
    FC: 0
    PH: 7.6
    TA: 100
    CH: 260 (much better than the 460 I had before)
    CYA: drum roll please.......70
    I dumped 4 182oz bottles of bleach then tested 3 hours later (7 hours after refilling)
    FC: 12
    PH: didn't test because FC was over 10
    TA: 110
    CH: 260
    CYA: 60
    I will perform the overnight FC loss test tonight. Should I drain more to bring CYA even lower?
    I'm not looking forward to my next water bill but I am looking forward to not going to the PS anymore.
    Jason M.
    BBB since 6/11/09
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    you can do what you want, but I'm around 70 and it's working fine for me.
    Jan 2009
    Cupertino, CA
    1,966
    In Texas summer heat, CYA 60-70 is not unreasonable. It will drop slowly over time as you backwash and replace water.
    --paulr
    BBB "Intermediate Swimmer"
  20. Back To Top    #20
    11,969
    I'd go with it for now, it will slowly drop over time. I ran with 70 for a summer, it's doable.
    Great job!
