Page 1 of 2 12 LastLast
Results 1 to 20 of 37
Thread: CYA Problem URGENT
    CYA Problem URGENT
    Hi guys some questions id like to ask, test results below:
    - Can high CYA like 70 ppm cloud pool water?
    - Do you think i should shock with MPS?
    - Should i also add algecide to pool whilst shocking with MPS? How much MPS should i use?
    - Any other recommendations for treatment?
    THanks a 1000
    Test Conditions as such:
    Water Clarity: Dull
    Temp: 30 C
    pH: 7.5
    TA: 80
    CAL: 140
    FCL: 2.6
    TCL: 2.9
    CYA: 70
    Fe: 0
    Cu: 0
    Pool Size: 20,000 gallons
    27,500gal IG plaster that needs recoating/painting!, Pentair Whisper-flo 1hp 2 speed, 48sf DE, Pentair Legend II pressure-side cleaner, BBB newbie
    Re: CYA Problem URGENT
    Oh and btw if i do a bucket test and find a Cl Demand needing say 50 ppm FCL, can i add at smaller doses and maintain my Cl @ 6 - 7 ppm for extended periods instead of shocking?
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    cya of 70 is high (assuming no swg) but not unmanageable. mine is 70. mps isn't recommended. algaecide isn't recommended. yes, see pool school, there's a lot of good information there that will help you. after you read it a couple times, ask more questions if you have them. also, you need a good test kit. pool-school/
    With CYA of 70 you need to keep your FC level at 5 or higher at all times, otherwise algae can get started.
    You need to shock the pool, see this article at Pool School for instructions.
    No you can't maintain a lower FC level for a longer period of time. That won't kill the algae. If you had an ammonia problem that would work, but that isn't the problem you have.
    - i dont understand why it isnt recommended to use Mono Persulphate besides that it is a chlorine reducer, doesnt it burn
    the organics?
    - if i feed Bromine and bring to shock lvl since iv got a very oversized feeder would it work good with Monopersulphate?
    at least the Bromine doesnt go into dead lock with the CYA?
    - lastly can i add Benzyl ammonium chloride?
    sry so CYA in itself doesnt not cause a clarity issue?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    No. it doesn't, your clarity issue is because your chlorine level is too low.
    You need to shock the pool as Jason advised above. MPS is recommended for indoor pools.
    If you just follow the steps in the article Jason linked you will be fine.
    Just use chlorine, it's ALL YOU NEED.
    Sry just trying understand more about pools & spas:
    -So besides the cost factors is MPS plausible? Or should it only be used with Bromine?
    - What Cl levels are safe to swim with my CYA?
    The only serious "problem" with MPS is that it costs more than chlorine. In an outdoor pool chlorine is just as good or better in every way and costs less. MPS has some advantages for indoor pools. Also, MPS is an oxidizer but not a sanitizer. You have to use chlorine anyway, to have some sanitizer. It is much simpler to just use chlorine, rather than keep track of two different chemicals. Also, MPS will register on the test as CC, which makes it difficult to know what your CC level actually is.
    Bromine is not a good choice for an outdoor pool, since it can't be stabilized against sunlight. You end up losing all of your sanitizer each day.
    CYA is only a problem if the level is too low or too high. As long as you keep the CYA level in the appropriate range, CYA helps dramatically.
    11,969
    Quote Originally Posted by aho.lwi
    Anything above your "min" and up to "shock" level.
    - So in other words MPS would and can cure an algae problem, what about h2O2 can they be considered same?
    - Iv still got around 25lbs of BCDMH left so you think it would be good as a short term replacement to my TCCA? besides
    i have no where else to use these tablets so....., but definately ill be switching to BBB method.
    - So are you saying FC of 8 or 14 would still be safe for me because of my CYA?
    11,969
    [quote="aho.lwi"]- So in other words MPS would and can cure an algae problem, what about h2O2 can they be considered same?
    - So are you saying FC of 8 or 14 would still be safe for me because of my CYA?[/quote]
    Yes.
    (I'll let the REAL chemistry experts tackle your chem questions....)
    eagerly awaiting.
    is there anyone around that could give me some directions
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    there are, just not this second perhaps. it's barely been an hour :)
    Mar 2007
    San Rafael, CA USA
    12,082
    MPS will not cure an algae problem. Though it oxidizes some organics, it does not kill algae as quickly as chlorine.
    H2O2 is hydrogen peroxide and is incompatible with chlorine (it will use up chlorine if you add it to the pool). Think of it as a chlorine neutralizer, so don't use it.
    BCDMH is for bromine. You do not use this in a chlorine pool. Once a pool has used this, it is stuck as a bromine pool for a very long time. If you had a spa, you could use the BCDMH for it. Since there is no protection of bromine from breakdown in sunlight, the bromine or chlorine demand in such a pool is high if it is outdoors exposed to sunlight (though your CYA does somewhat help protect the lower depths of water from such sunlight).
    Yes, an FC of 8 or 14 is safe for you assuming your CYA is at 70 ppm. The normal range would be an FC no lower than 5 ppm and usually not higher than 10 ppm though it can be 14 if need be (but you should be able to maintain a range such that you don't lose more than 50% FC per day -- and at a CYA of 70 ppm you should be able to lose only 20-40% per day).
    Richard
    30,426
    aho.lwi,
    What is the urgency of your situation?
    Thanks for the help guys.
    Last Few Question:
    - Since MPS and Hydrogen peroxide are both oxygen releasing why does one destroy Cl and the
    other doesnt?
    - So in other words MPS does kill algae just that it isnt fast like Cl?
    - So in other sodium percarbonate is no good for a Cl pool as well?
    -would it be better i just leave my Cl levels at 15 - 16 ppm rather than bring my FC to shock of 20 ppm for extended periods?
    - iv got two pool parties at my house one today and the next tmrw and so im wondering if i could just maintain higher doses of CL instead of shocking
  20. Back To Top    #20
    -Also im a little confused calclulator say Cl 20ppm for shock and chart says Cl 28ppm?
