Results 1 to 11 of 11
Thread: CLOUDY Water - Please Help!!!
    I recently setup my above ground 18 ft pool, and I have cloudy water. My tests are as follows:
    Total Hardiness: 400
    Free Chlorine: 2/4
    Ph: 7.5
    Total Alkalinity: 180
    Cyanuric Acid: 30/50
    What do I need to do to clear up the water? I am open to any suggestions.... I have a a Lil Shark vaccum how often should I use it, or just vacuum in general....
    Thanks for all your feedback,
    Jeremy
    Pool Type: Alantis 18 Ft Round, 52" Above Ground Pool
    Pump: Sta-Rite JQPA5E
    Sand Filter: Sta-Rite T-200BP-1
    Vacuum: Basic one that came with pool, and a Sta-Rite Lil' Shark
    Chemical Brand: BioGuard
    Jeremy
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: CLOUDY Water - Please Help!!!
    Hi can you put your pool info in your signature, this will help those answering your questions.
    Go to User Control Panel, top left, then Profile, then Edit Signature.
    type of pool, surface, gallons
    type of pump, type of filter, any other pertinent information.
    2/4 FC ? How did you obtain your test results? (test strips, droptest kit?)
    Welcome, we'll get you straight!
    Welcome to TFP!
    It sounds like you are using test strips. Test strips are not the best way to test your water. They give vague results and can occasionally be totally wrong (especially on the CYA test).
    What color is the cloudy water? If it is very white, like milk of fluffy clouds you might have calcium clouding. Otherwise you have algae. For calcium clouding you should lower your TA level. For algae you should shock the pool.
    The pool is just cloudy I think from dirt. What color is alge? How many hours do you typically run your pump?
    My pool info is as follows:
    Jeremy
    Jeremy
    11,969
    So it's brown in color?
    Test strips?
    HTH 6-way test strips, I would say cloudy... somewhat white.
    Jeremy
    11,969
    How long have you been running your pump? When was the pool filled...have you been adding chlorine every day?
    If you haven't read Pool School - that would be good place to start.
    Chances are you just don't have enough chlorine in your pool - for your current CYA level. Refer to the CYA chart. Are you using tablets/sticks for your chlorine source?
    I run the pump everyday for 6.5 hours. The pool was filled about a month ago. I add chlorine as needed. I add chlorine by the tablets in the floating thing in the pool. I will check out the pool school... Thanks for the advice...
    Jeremy
    11,969
    Yes, check out Pool School. Start with Recommended Levels, How to Shock your Pool, and while you are shocking run your filter 24/7.
    AFter you clear this up, you may want to run your pump more....I'd start at 12 hours and work your way down till you find your optimal run time.
    I'd also advise you to ditch the strips and invest in one of the recommended test kits.
    After you have read Pool School, don't hesitate to ask if you still have questions/concerns.
    Thanks for all your help frustratedpoolmom. I appreciate it........
    Jeremy
    11,969
    No problem.
