Thread: difference between clarifier, super clarifier, floc?
    May 2009
    Jasper, TN
    249
    I see SO many products for clarifying water. And what's even more confusing is that some manufacturers market products such as clarifier, super clarifier and floc clarifier, and all 3 has basically the same description on what they do.
    I can see how different manufacturers will want to market their own brand, but when the same company has more than product that does the exact same thing (seemingly).... why?
    Or is there a difference?
    Which is best for just occasional water polishing?
    24' x 52" AGP = 13.5k gallons
    Dynamo 2.0 HP pump,Sand Dollar sand filter
    Polaris 65 vacuum (good when there are a ton of leaves on bottom), Pool Rover Jr. (LOVE it, but power box dead right now), AquaCritter (an excellent suction side cleaner)
    30,285
    Re: difference between clarifier, super clarifier, floc?
    Always being the cynic, I would say, "not worth it, even less worth it, and completely worthless"
    My point is that in a properly chlorinated pool, you will never have a need for any of these.
    Like everything in life, there are times when the above statement is probably not true. Most BBB'ers would have a hard time finding those ocassions, however.
    What duraleigh said 8)
    Clarifier causes very fine particles to clump together so they can get filtered out. Floc causes both very fine and slightly larger particles to clump together so they fall to the bottom and can be vacuumed up. It unusual to need either one, and even when you do need one, they don't always work.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,965
    Ditto. What Dave said.
    http://www.PerfectlyClearPoolService.com
