Thread: Impeller breaking
    Impeller breaking
    I have a strange issue. My pump/motor is repeatedly breaking the impeller. I replaced two last year and just completed the replacement of another one this past Sunday. Three days later (today) I check the pool only to hear that familiar whine again. THREE DAYS!! The Pump is a 1.5 HP. I have 1.5 inch PVC from the motor to the sand filter. Please help - the people at the "pool store" don't have a clue. (But they are getting the part back tomorrow, they just don't know it yet LOL) Thanks!
    My Pool - 21,000 Gallon Plaster In Ground Manatee Shaped Diving Pool - Sta-Rite Dura-Glas Pump 1 1/2 hp, 3450RPM, 48Y Frame, 230/115 Volts, 60hz., 9.6/19.2 amps - 24" Jacuzzi Bros Sand Filter 60 GPM (46 Backwash)
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Impeller breaking
    As in it's stripping the threads so that the motor shaft just spins inside the impeller?
    If that's the case there's something putting resistance on the impeller, either a piece of plastic that's out of whack or maybe the impeller you're getting is too big for the motor. What's the impeller part #, motor HP and SF?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Is there a basket inside the pump basket to trap debris?
    Mark
