Thread: Is there a sticky on chems??
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    I'm starting up a new pool and am needing to do 2-3 different things to my water. I was wondering if there is somewhere on here that tells what chems you shouldn't add together. I pretty much know what I need to add, just didn't want anything to meet together in the water and not like each other
    Thanks
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    Re: Is there a sticky on chems??
    I thought there was, but cannot seem to locate it.
    A safe bet would be to wait an hour with the pump running between each addition.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    mas985's Avatar
    Pleasanton, CA
    11,741
    Chemicals one might add to a pool:
    Acid
    Baking Soda
    Borax
    Acid pretty much does not mix well with any of the other three in high concentrations so don't ever mix different chemicals in a bucket or other small volume. However, in a pool, chemicals dilute very quickly so there shouldn't be an issue adding chemicals one after another but if you really want to be safe, always add acid on the other side of the pool. But really, you should never need/want to add acid with Baking Soda or Borax (counter productive) so the only real issue is acid with chlorine.
    Mark
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Thanks guys. What about calcium chloride??? My CH is very low. 80 and should be around 250 for FG pool, I think.
    Lynn
    To be completely safe it is best to add CH only on a day when you aren't adding anything else (except the routine chlorine dose).
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Thanks Jason. I believe FPMom told me the same thing
    Lynn
