Results 1 to 13 of 13
Thread: BBB going OK but maybe some numbers should be tweaked
    Oct 2007
    Central Texas
    104
    I have been having trouble getting FC with the Liquidator. I run the Intelliflo VF at 50 gpm 24x7 and this doesn't produce enough flow through the LQ. I am looking at adjustments now. I am also adding 60 ounces of MA twice a week.
    I was wondering the following.
    Should I raise TA?
    Should I lower CH?
    Should I raise CYA?
    FC 2
    CC 0
    TA 40
    PH 7.6
    CH 525
    CYA 30
    Light grey plaster, stone coping, 38K gallon Roman shaped pool with a shallow end beach, table and bar stools, deep end bench and waterfall (Intelliflo 4X160). Taylor K-2006, Pentair 320 chlorinator, Intelliflow VF, Quad DE 100. 4 ColorLogics, 3 skimmers, 14 wall returns, 13 floor returns, TurboTwister slide, autofill and miles of pvc.
    Re: BBB going OK but maybe some numbers should be tweaked
    in short - yes, yes, and yes
    Intex 24' by 52" round metal frame vinyl holding about 12,500 gals.
    Krystal clear Model 633 Filter Pump Cartridge 1/2 HP Pump
    TF Test Kit (Thanks Dave) Located Central Texas Coast
    how does your pump run with so many returns? jeebus. sounds fun though.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    wow, do you have pictures of that pool?
    30,427
    Hi, Carlos,
    Yeah, I would.........
    1. Raise CYA to 50 or so
    2. Raise TA to around 100
    3. Reducing CH can only be done thru drain and refill.
    If you keep you pH down in the low to mid 7's and your TA not higher than 100, I believe you can manage your CH without problems.
    That will likely reduce your acid consumption as well. Raising your CYA will certainly reduce your FC consumption and allow the LQ to better keep up.
    Bob_Funk's Avatar
    May 2009
    Seattle-It really rains all the time
    113
    Quote Originally Posted by reebok
    I would also like to see pictures
    I consider myself very lucky I found this site before the pool store found me-pool owner since Nov 2008- Stunningly clear 17,000 gal fiberglass pool, thanks to this site, installed in 1982-24" 3.1sq. ft sta-rite sand filter, 1 hp - 2 speed wisperflo pump-WFDS-4
    Oct 2007
    Central Texas
    104
    I will raise TA and CYA but how much should I lower CH? We are under water restrictions and that is going to be a tough one to pull off.
    Here is an older pic - I will try to get some newer ones including the equipment pad.
    http://s371.photobucket.com/albums/oo15 ... t=pool.jpg
    Thanks.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    As Dave said, if you keep your TA and PH in range, high CH can be managed without draining.
    LOVE the barstools....
    Butterfly's Avatar
    South Carolina
    10,045
    Beautiful pool!
    I love the bar stools, too, but I'd have to hire someone to brush my pool if I had them!
    You're done SLAMing when:
    Oct 2007
    Central Texas
    104
    I have my made some adjustments and I am about to add borates as well. I wanted to ask about the TA recommendation of 100. 70 to 90 seems to be the normal range for plaster pools. What would higher TA provide to help me retain FC or stabilize my PH from rising?
    FC 5.5
    CC 0
    TA 70
    PH 7.4
    CH 525
    CYA 30
    30,427
    FC 5.5
    CC 0
    TA 70
    PH 7.4
    CH 525
    CYA 30
    1. How does your water look?
    2. If TA of 70 has stabilized your pH rise, then leave it right there.
    3. You still need to raise your CYA up around 50...you'll lose less chlorine.
    Oct 2007
    Central Texas
    104
    The water looks clear. I will need a week to keep an eye on the PH. Can I go ahead with the borates or should I wait until I am satisfied with TA?
    I added CYA yesterday but the test results didn't change much. I think I had less CYA than I originally thought. I am going to bump it another 20 today. I presume my test is valid 12 hours after the granules are dissolved in the skimmers? (nylon socks) The container did say to wait 7 days before testing????
    You should wait a week after adding CYA before testing the level. Even if all of the CYA appears to have dissolved, it doesn't always register on the test right away.
