Thread: Polyquat 60
    Polyquat 60
    Is the product by BioGuard (Algea All 60) the same as Polyquat 60.....After I get my water in order I need to deal with the stains again......
    17,200 in ground Vinyl pool......
    Salt Water
    Sand Filter
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: Polyquat 60
    Yes, it is.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: Polyquat 60
    It does appear to be Poly-Quat 60
    Found on the web...
    BioGuard Algae All 60® (Treatment & Prevention)
    Non-foaming 60% poly-quat effectively prevents a broad spectrum of algae. Great for use in situations where fountains, water falls, or other water features are a part of the swimming pool circulation system.
    According to the MSDS (which I found here- http://www.thepoolandspahouse.com/tools ... L%2060.pdf):
    COMPOSITION / INFORMATION ON INGREDIENTS
    Chemical Name
    Poly[oxyethylene(dimethyliminio)ethylene(dimethyliminio)ethylene
    dichloride]
    CAS#
    31075-24-8
    Wt.%
    60
