Results 1 to 8 of 8
Thread: Filter off, now cloudy
    so My power went out last night due to a thunderstorm... usually its only out for a few minutes, but this time the power was out all night turning my filter off... after 12 hours my pool was milky/cloudy... before the storm I raised my FC levels to 6 like I do every night(6% bleach)... all other chemicals are at the recommended levels based on pool school.
    my question is is there anything else I can do to keep my pool from getting away too far until power comes back on... its going to be 100 degrees here in missouri today
    thanks
    16x32 inground pool 3ft-8ft (18,000 gallons) Vinyl lining New DE Filter
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Filter off, now cloudy
    You'll need to use something to circulate the water and get some more chlorine in there asap. Use a pole brush or paddle or something and get to stirring....sorry this is happening.
    Butterfly's Avatar
    South Carolina
    10,045
    Sorry to hear of the power outage; however, your pool should not have turned milky/cloudy overnight.
    I run my pump/filter appx. 8 hours a day. Something like 11AM to 7PM. Never overnight-but that is just our choice.
    I agree with FPM that you need to get some bleach in there ASAP and mix as best you can. Brushing the pool would be a very good way to mix it.
    When your power comes back and you have your water circulating again, please post a full set of #'s and maybe we can help you figure out why it turned cloudy/milky overnight.
    You're done SLAMing when:
    yeah I thought it was very weird that it turned cloudy overnight... it has always been crystal clear, dunno if there was something funky in the rain water or what... oh well hopefully the power comes back on soon and I will get more chlorine in and see what happens... thanks for the quick advice.
    11,969
    Did any debris/organic material get blown in? That could contribute.
    just few leaves... Im heading home in about an hour so hopefully the power is back on, so I will get good Chem #'s for you guys.
    So the power guys are workin on the power now...
    But fc was 6 last night before the storm...
    Now fc 1
    Cc 0
    Ta 115
    Ph 7.0 <-- was fine on Monday
    Cya 55
    I dumped a 192 jug of bleach in and as soon as power comes back on I'm just gonna raise fc up to 15 and shock... and check the pool calc to see how much iborax I need to raise ph back to normal... the pool is fluttered with bugs, but I've had a bug prob since opening... but its sure strange how messed up things got with just 1 overnight storm, never had anything like this happen before....
    Any other advice?
    11,969
    Nope. Without power that's pretty much all you can do...
