Results 1 to 7 of 7
Thread: Why not Cal-Hypo if Calcium Hardness is low?
    Guest
    I'm wanting to raise my CH a little bit. Any problem with using small quantities of Cal-Hypo shock instead of bleach for a while?
    Any reason not to?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Why not Cal-Hypo if Calcium Hardness is low?
    What is your CH level?
    Woodberg's Avatar
    Apr 2009
    Houston, TX (Candlelight Estates)
    136
    That should be fine. You may want to brush the bottom of the pool just to make sure it dissolves all the way.
    20,000 gallon gunite pool, attached spa, Pebblesheen finish, Paramount PCC-2000 infloor cleaning system, Paramount ClearO3 ozone system, Intelliflo VS main pump, Whisperflo 1HP cleaner pump, StaRite cartridge filter, StaRite heater
    11,969
    First, What is your CH level?
    Edit: Based on a post you made on Monday, your CH level is 230 which is not low, it's just fine for fiberglass. End Edit.
    11,969
    Quote Originally Posted by Woodberg
    It depends on his current CH level.
    Guest
    My CH level is 220, so it's not real low. waterbear recommended getting it up a little higher due to my staining problems.
    I thought it might be a good opportunity to kill two birds with one stone. chlorinate and also get the CH up a little at the same time.
    11,969
    Then Cal-Hypo is fine. Use the "effects of adding chemicals" to determine how much the cal level will be raised with each addition.
