Thread: 3way valve question
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    3way valve question
    I told the icompetent guys building my pool to take out the ball valve on the waste port and put a 3way where you see it now. (Good suggestion by spishex) Well I'm glad they left the ball valve cause when I opened it water came out the waste port.
    Could someone explain the mechanics of the 3way???
    Is it installed correctly?
    Should I just leave things the way they are???
    Thanks
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: 3way valve question
    The valve shuts off the port it is pointed towards. So to shut off the waste, point the valve toward (handle away) from that port.
    Mark
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    That's what I needed. Thank you Mark.
    Lynn
