Thread: Wood fired pool heater
    Thinking of using my domestic hot water coil in my wood boiler to heat my pool for the summer. Does anyone know if this will work or am I wasting my time?
    25,000 gallons,sand filter,IG,vinyl,SWG
    test
    chlorine: BASE 0
    Free Chlorine: 0
    pH: 7.6
    Alkalinity: 120
    Stabilizer: 30
    Hardness: 350
    Ammonia: 2.0
    Salt: 3510
    30,415
    Re: Wood fired pool heater
    Hands on personal experience.....waste of time. Your heater is w-a-a-ay too small.
    Welcome to TFP!
    Swimming pools need a huge amount of heat. A typical pool heater is around 200,000 to 400,000 BTU, while a typical water heater might be 30,000 BTU.
    I have known people to use a wood fired boiler with success, they were both 24' round above ground pools. Make sure it has a SS coil that your pool water runs through and that your lines can handle the temperatures. If I remember the Btu ratings were around 100,000-150,000.
