Results 1 to 10 of 10
Thread: OLD TROJAN POOL COPING...8"..CANNOT FIND???
    rentzie's Avatar
    Winnipeg, CANADA
    2
    Good day eh!!!.....I am up in Winnipeg, Canada and need some replacement coping for my old TROJAN inground pool...cannot get it up here...anyone know where I can get some???...one of the pool guys said something about New Jersey or something???? This is the old 8" stuff.....HELP..?????
    Way up North eh!!!...with old 16 x 36 TROJAN inground pool, sand filter, solar heat...need new liner....$$$$
    Dec 2007
    Central New York
    504
    Re: OLD TROJAN POOL COPING...8"..CANNOT FIND???
    Try this search:
    http://search.yahoo.com/search?n=10&ei= ... round+pool
    Also, Trojan Pools, is now know as Radiant Pools.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Hi - did you have any luck in locating this coping? I'm looking for the same, plus the clips. Radiant (formerly Trojan) don't have the clips. Said their mold broke. Any info is appreciated.
    May 2015
    Kennesaw, GA
    29
    I'm struggling with a similar problem with what I believe is an older Spartan pool. Similar coping but only 6.5" - see picoldcoping.jpg. Would appreciate any thoughts. FYI, I've already checked with Cinderella, so please don't recommend them.
    Leo In Kennesaw, GA
    Older 40x20 rectangular pool
    38,000 gallons
    Vinyl In-ground - Buster Crabbe
    Pentair Chlorinator - Salt - SWG
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,087
    You might give vastec a call.
    they focus on aluminum coping for fiberglass pools, but do coping for vinyl too.
    no clue if they have exactly what you need, but its worth a try.
    Aluminum Coping, Fiberglass Pools, Pool Coping - Vastec USA
    Divin Dave,
    Feb 2016
    Mn
    5
    Quote Originally Posted by rentzie View Post
    Hi do you Still have the pool, if so how old is it and is still in good shape I'm thinking about buying a radiant pool but heard that they corroded Easy should I stay away from this type of pool ?
    Thanks
    Jul 2016
    west hurley/NY
    2
    I have 7 clips, 3 straight coping sections and 7 angled copings sections. The coping measures 7 1/4 inches and the clips measure 7 1/2 inches. There are 17 ridges on the coping. Anyone interested.
    Jun 2017
    Fenton
    1
    Quote Originally Posted by sfhajek View Post
    anyone know where i can get some of this coping used or new ?????
    I am in desperate need of this coping if there is anyone that knows where i can get ahold of some new or used ?????
    edit by Jim R.
    Jun 2017
    Salt lake ,Utah
    2
    I was just checking to see if this coping is still available. I think it is exactly what I am looking for.
    Jun 2017
    Salt lake ,Utah
    2
    I am in need of coping for an old Trojan in-ground vinyl liner pool. 8 in. Wide. Cannot find
