Thread: Filter issue?
    WestSidePool's Avatar
    Cincinnati, OH
    424
    Filter issue?
    Last night my water was cloudy and i checked my filter.
    The filter pressure was up about 8-10 over the start line.
    I back washed, and rinsed and put in new DE powder.
    I then shocked the pool, and put in some liquid algae prevention.
    This morning i went out and checked the clarity of the pool (it cleared up) but my filter pressure was way up again...
    What would be causing that, or how do i go about fixing it?
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Filter issue?
    Your filter is removing whatever particles are/were clouding the water. Backwash and add DE again (about 80% of a full load). If you continue to experience increasing pressure even with clear water then you'll want to disassemble the filter and clean it manually.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Filter issue?
    Welcome to TFP!!
    Spishex always gives solid advice - you ought listen to him This thread has my advice on caring for a DE filter 8)
    Luv& Luk
    -Ted
    30,426
    Re: Filter issue?
    The title of your post is probably a little off the subject. Chlorine is most likley your issue....not the filter.
    If you post a set of test results, I think we'll probably see your FC has returned to a level too low to protect your pool.
    Your psi rose after the dosage (as sphisex said) because you killed some of the algae in your pool and it moved into the filter causing the pressure to rise. I doubt you killed it all, however, and think you will need to shock more thoroughly but only test results will tell us for sure.
    Cincinnati, OH
    424
    Re: Filter issue?
    Thanks for the replys.
    I need to get myself a test kit that tells me all the exciting stuff.
    The one they gave me only test PH and CH.
    Eric
