Thread: Which number is correct - aquapure or test strips
    May 2008
    Hockessin, Delaware
    48
    My salt reading on aquapure is 2500 but aquacheck test strips say 3240. Which is more accurate and how do i calibrate aquapure if strips are correct ?
    21 X 42 freeform gunite pool w/ spa
    white plaster finish
    Jandy VS ProFlow Pump
    3 returns, 2 skimmers
    pentair DE filter
    Aquapure 1400 SWG
    Raypac 399,000 BTU Heater
    Zodiac Nature 2 Pool sanitizer (haven't used yet)
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Which number is correct - aquapure or test strips
    I have found that most SWG cells will read slightly lower than the tests but yours is reading quite a bit lower which might indicate it either needs cleaning or it could be at end of life. Try cleaning first before calibration. Also, how old is the cell?
    I did a google search and came up with this procedure for calibration.
    Mark
    Jun 2007
    Arlington, VA
    29
    It may be the strips. I had not-yet-expired strips go bad earlier this year. In my case the yellow line at the top of the strips had turned partially brown.
    ____________
    34,000 gallon pool with charcoal Marquis aggregate finish
    Jandy stealth pump, cartridge filter and Aquapure SWG
    Solar heating with Goldline controller
    Polaris 380 Blackmax
    May 2008
    Hockessin, Delaware
    48
    Salt cell is in its 10th month of use. I just cleaned the cell but it looked great. I cleaned the sensor also. I did notice that the band at the top of the test strip(aquacheck white) did not turn brown like they said it would. Are the strips bad? Expiration on them is 9/2010. I thought my salt reading should be low because we have had a ton of rain in the past month. I have had to empty water on 2 occasions. It is hard to believe that the salinity is still 3320 per the strips. Aquacheck light is now on saying to add salt (2400 ppm).
    pentair DE filter
    Aquapure 1400 SWG
    mas985's Avatar
    Pleasanton, CA
    11,741
    Bottom line is that it really doesn't matter what the strips say, you need to keep the SWG happy. Target the low end of the SWG recommendations and go from there.
    Mark
    May 2008
    Hockessin, Delaware
    48
    Update - Added 80 lbs of salt and generator reading went to 3000. Did the test strip reading and it was exactly the same as the previous reading before the salt was added. Bottom line is the strips must be bad.
    pentair DE filter
    Aquapure 1400 SWG
