Thread: Discolored Plaster
    Discolored Plaster
    Hello Everybody.
    I need some help with my plain gray colored plaster.
    Here are some links showing a light discolored area that appears to "flow" from shallow end to deep end. Also, there appears to be a round sort of pooling area in the deep end.
    This pool was finished last November.
    I have also included a picture of some stains on the plaster where they dropped sealer. This is around all of the pool, some of it is just dark areas, some has chalked up like bird poop.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Discolored Plaster
    Plaster does have the tendancy to mottle over time but I think it is too soon for that. I would say this might be a problem with the installation and you might want to have a talk with the installer.
    Mark
    34
    What brand of plaster is it? There is vast differences in the dyes used in pool plaster and application. Have the plaster council do an inspection. Google National Plaster Council
    Quote Originally Posted by Frank R
    I did this and found that the people who applied the plaster are members of the NPC. Who specifically do I need(manufacturer, appliers, etc.) to do this inspection?
    Also, The sealer got on the plaster when one of the contractors morons sealed the coping before the pool had filled with water.
    34
    Under Technical Information link on the left, you will find a link for pool inspection. They will schedule one for you. You will then have an evaluation from an expert in the industry. I hope this helps.
    Sep 2009
    Gulf Coast Florida
    13
    I could be wrong, i have seen this before. I think it is from the plasterers using water when they did the final hard trowel. with the water at the end, the pigment started to come out of the plaster.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist $600 w/part of deck included), 13,500 gallons, Intex SWG, solar panel
    My backyard is like a park... Why then does DH always want to go camping??? I just don't understand.
