Thread: from Ohio
    r4m's Avatar
    Louisville/ Ohio
    40
    from Ohio
    Hi! I am Bill. I'm from Ohio. I'm getting a 27 ft round above ground pool and looking for tips for purchase and upkeep. Looks like I come to the right place.
    Purchase tips now to avoid regrets are welcome.
    Thanks
    Bill
    27 ft round, 19,400, cartridge filter
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: from Ohio
    Welcome to TFP,
    Pool School at the top of the page is the place to start. A good test kit will save both time and money in maintaining your pool. I'm bias to the TF100, link in my signature, or a Taylor K-2006. Thie differences are outlined in Pool School article.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Butterfly's Avatar
    South Carolina
    10,045
    Re: from Ohio
    Hi Bill and welcome to the forum
    Yep, what Dave said
    We're glad to have you.
    You're done SLAMing when:
    Re: from Ohio
    Welcome to TFP, neighbor!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Jun 2008
    Texas
    132
    Re: from Ohio
    Hi Bill,
    I am one of the few Buckeye fans in Texas. [Go Bucks ] Reading the articles in the Pool School, buying a good test kit, and using the BBB method will save you time, effort, and money.
    By doing your own water testing you will test frequently, prevent problems quickly, and achieve accurate results. If you are dependent on the pool store to test you will test perhaps weekly, the test results will be very suspect, and they will talk you into unnecessary products.
    We had several expensive years and way too much work until we avoided pool stores. I buy all chemicals in the laundry isle of Walmart or at Lowe's.
    Read & learn. You will be able to enjoy your pool.
    Welcome to TFP.
    30,000 gallon gunite in-ground with a spillover spa, Diving board and water slide
    Hayward 1 HP Super II filter pump, Hayward 24 " Sand Filter Pro Series using zeolite media
    Polaris 380 cleaner with ¾ HP booster pump, Hayward Heatmaster pool heater, AutoPilot DIG-220 Power Supply SC-60 cell
    Testing with the TF-100 Test Kit
    r4m's Avatar
    Louisville/ Ohio
    40
    Re: from Ohio
    Thanks for the warm welcome everyone! I've been reading some of the info here at the site and learning a little. I've just about committed to a 27' round pool with a 2 speed motor and a cartrige filter. It is a total package deal that includes install and all the stuff to startup.
    I'll prolly be around quite a bit this summer with lots of newbie questions.
    thanks,
    Bill
