Page 1 of 3 123 LastLast
Results 1 to 20 of 54
Thread: Pristine Blue to Chlorine
    Jacksonville Fl.
    21
    Ok, I will first admit I got suckered into the Pristine Blue(PB) ****. After reading on and off for 2 days I was quickly convinced that PB is not the way to go so my question is how do I go about converting? This pool is only two weeks old so not much of that **** is in there.
    Is it possible without draining the tank? I've read that I can do it w/o draining but the copper will always be in there....is that a bad thing?
    I obviously need to test water, get ph to 7.2-7.4 then shocking...am I correct?
    So I go to pool place, get water tested and buy a bunch of chlorine.....will they pretty much tell me what I need to do? Will I have to change my sand filter and if so how much does that cost?
    Thanks for any help. I am looking to starting the process asap.
    Oh and whats the difference between BBB and chlorine pools?
    Sean
    14000 gallon, AG, Sand Filter and know idea of pump flow rate....
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Pristine Blue to Chlorine
    Hi there - did you read other topics about Pristine Blue? Have you read Pool School? The BBB method is explained there. Read all the articles, and it will start to sink in.
    Converting to BBB after using Pristine Blue isn't the same as converting from Baquacil, which requires shocking and changing sand.
    You'll need to get a full set of test results, especially for copper, from the pool store. DON'T BUY anything from them or listen to their advice.
    Come back here, post your results and we'll get you straight.
    Jacksonville Fl.
    21
    Thanks! I did read SOME of pool school but there is A LOT of info there. I'm going to another pool store from the PB people. I feel like I've been lied to . I will post the results and what they recommended.
    Thanks again.
    Sean
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Pristine Blue, which contains copper, is not an EPA approved sanitizer.
    It is a pesticide. Your best bet would be to drain and refill, unless some of the chem pros here recommend a specific sequester. There's a problem with that because the copper is most likely chelated, which means it is bound by another chemical.
    Just to prove to you that your pool store "learned advice" is bad: Pristine Blue's web site http://www.pristineblue.com/faq.asp warns not to use it for 0-6 months old pools.
    Shy away from pool store's recommendations. They are in the biz to sell chems, not to help your pool. Their "free" water analysis is their best tool to sell you what you don't need.
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    11,969
    Since it's only been 2 weeks, lets have a look at the copper levels before you decide to dump.
    Jacksonville Fl.
    21
    Wifes at the pool place, I just got off the phone with the guy. He's say's that there's 0 chlorine and he is going to try to make is 3 ppm. Also, he said that "the copper will eventually float out and get flitered" when I asked about a Copper sequestrant. My wife wants to do exactly what they are telling her to and I am trying to tell her that they might be feeding us **** we don't need.
    Here are the "numbers" from my wife over the phone:
    0 chlorine
    20 Stabilizer
    7.6 ph
    125 hardness
    110 alkalinity
    So what you think?
    11,969
    Your numbers are all good and don't need changing except for the chlorine. You do need a little stabilizer, or Cyanuric Acid.
    We need a copper level reading to know for sure.
    Jacksonville Fl.
    21
    Thanks for the quick response! That's what I told the my wife but she dismissed it and the pool guy didnt have a clue about it or he would have tested for it. So, 100% without a doubt, my pool will get stained if my copper is too high? I just added the Pristine Blue two weeks ago and it was "good" for there system. We just tested in a crappy tester and it was .2.
    So what ya think?
    Jacksonville Fl.
    21
    He also said we need a calicum hardner since it was at 125. . . . 32 lbs of hardner, is that correct?
    11,969
    No. Calcium is not necessary in a vinyl pool.
    11,969
    If your copper level is .2 and not enough to worry about.
    Get some liquid chlorine or bleach, some stabilizer/CYA and you are golden.
    Jacksonville Fl.
    21
    ok, talked to the pool guy again and he dropped the ball on the metal. They test for TDS (he said is total metal and not just copper) and it was 3000ppm but he missed it and didn't give my wife anything for it. He said it is supposed to be below 1500ppm. Sound right? He said I can stop by and pick something up for it....
    Prior to knowing this my wife put in the Calcium and Stabilizer. . . . .but no Chlorine and told her not to until we get the TDS down. Am I on the right path so far?
    Sorry about bombarding you with ?'s, just don't want to mess it up.
    Also, 2.5 gallons for chlorine about right? Tested and it was Zero.
    Jacksonville Fl.
    21
    one more....will the calcium hurt the pool? the pool dude swears I need it or the liner will rot. I didn't want to argue with wife so we just put it in.
    11,969
    TDS is a crock. Don't worry about TDS and he is totally Pool Storing your wife. Gawd sometimes I despise pool stores! Calcium levels as low as 50 are fine for vinyl liners. The guy doesn't know what he is talking about. The main thing that will hurt your pool liner is low PH (and high levels of COPPER! LOL)
    Metal testing is a separate test all together, and if your cheap metal test kit said your copper level was .2 then I would go by that. Or find a different pool store and ask them to test your Copper and Iron levels.
    Regardless, find a different pool store. This one will bleed you dry.
    11,969
    Oh on the chlorine - what strength are you planning to use?
    11,969
    How much stabilizer did your wife add?
    Jacksonville Fl.
    21
    On the Calcuim, when they tested it it was 20 so it was right to add right and bump it up over 50?
    SoduimHypoChlorinte 10.5% . . . . .. He said is "premixed". . . it's a liquid.
    Sorry about the confusion, doing this all over the phone.
    Jacksonville Fl.
    21
    2 lbs of sanitizer and she says its just sitting at the bottom of the pool. . . I told her to move it around once and a while... . . .I read that on here somewhere LOL. I think.
    11,969
    Okay I see now, your Total Hardness was 125.
    Your calcium alone was 20? Okay the calcium addition was fine (not necessary but harmless anyway)
    If you use 10% you'll need about 1.4 gallons to raise your FC up to 10, which is a good way to start.
    Stabilizer - you need to vacume that up into the filter asap and then not clean/backwash the filter for several days, to let it dissolve. Run the filter non stop for 24 hours while it's dissolving in the filter.
    Have you used the pool calculator yet? IT will help you figure out how much of each chem to add.
    Test your chlorine each nite, you'll need to add some each night to keep your FC levels according to your CYA level - refer to the chart.
    I advise you to invest in a good test kit, either the TF100 or the Taylor k-2006. Then you can avoid the pool store.
  20. Back To Top    #20
    Jacksonville Fl.
    21
    Ok, now I'm kinda getting it. Two question in normal peoples terms. FC is going to be around 10 but the other chlorine is at 3ppm? Whats the diff between the two and whats the other chlorine (like FC). . . . .
    Secondly, which test kit would you recommend and where can I buy it. No problem buying it online either. . .
