Results 1 to 19 of 19
Thread: mustard algae or yellow algae.....
    mred's Avatar
    Sep 2008
    everywhere
    29
    i dont care what its called
    sorry if i am coming off really rude but i am at the end of my ROPE!
    my chemicals are fine they read.
    fc =3.0
    ph=7.6
    ta=150
    this all i have.
    now the phosphate level was high.
    so i was told add 2 pints of phosfree from leslies .....
    i just want to get rid of this ****.
    please help
    i have brushed the pool like mad. i brushed all the yellow stuff to the deep end and let the main drain suck it all up. then i added the phosfree the skimmer,and when i got up this morning i had to back wash my pool. i just now vacuumed the pool.
    what gives folks?
    im so aggravated, i have wasted money on chemicals,time,and gas...
    to top it off i was laid off from work.
    thanks
    Ed
    "Dry Gun" inground, Hayward 6020 D.E.,1/5HP
    30,000
    30,395
    Re: mustard algae or yellow algae.....
    Virtually every algae problem is a lack of chlorine in the pool. Chlorine must be kept in your pool constantly and never allowed to drop below a certain level.
    That "certain" level depends largely on how much CYA (stabilizer, conditioner) is in your pool. If you could get a test and post that number, we'll be able to help you get rid of the algae.
    Do not purchase any more stuff from the pool store. Phosphates are not an issue in your pool.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    if you click on pool school in the top right of every page, there is a lot of information that will shed some light on pool chemistry which the pool stores won't tell you because they want to make money on phos-free and all the other expensive chemicals. it will also tell you how to solve your problem and there are many people here to help as duraleigh said.
    mred's Avatar
    Sep 2008
    everywhere
    29
    you know i should just kick the **** out of myself!!!
    i told myself to do all of what the pool school forum said to do but i was over analyze the pool, as i do everything.
    i just threw about 4lbs of shock in and went to brushing the pool and i will back wash in 24hrs and vacuum the pool and back wash again.
    30,000
    What is your CYA level? You really need to know your CYA level!
    Once you know your CYA level, you will know how much chlorine you need to add. Just tossing in some random amount of chlorine might work, or it might be too little, or it might be way too much. If you don't know what all of your levels are, you are just guess and much more likely to be wrong than to be right.
    mred's Avatar
    Sep 2008
    everywhere
    29
    i think the cya has been way to high for some time now.
    because all i have been putting out before today was chloribrite.
    which is full of cya that is the stabilizer correct?
    plus my tablets have a stabilizer in it also,correct?
    jason' i agree with you 100% my kit test kit does not test for cya.
    but if memory serves me right,last year i ran into the same issue,with to much cya levels.
    30,000
    mred's Avatar
    Sep 2008
    everywhere
    29
    Quote Originally Posted by Casey
    If your CYA is at 100, then it could actually be over 100!
    Super-chlorinate with unsented bleach but... before you actually do that, I'd highly recommend partial drain/refills until your CYA is at 50. I mean, that's what I would do if my CYA was at 100 and ^.
    If you don't have enough CYA, your FC is ineffective.
    You have to have a HaPpY MiDdLe!
    If you have too much CYA, your FC is ineffective.
    Good Luck, Welcome to TFP and keep us posted!
    this rung my bell!!! $45 to late though.
    30,000
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by mred
    If you are talking about Leslie's Chlor Brite, then this is Dichlor and probably the most irresponsible product on the market when advertised for use in shocking a pool with chlorine. For every 10 ppm Free Chlorine (FC) that it adds, it also increases Cyanuric Acid (CYA) by 9 ppm.
    And yes, your Trichlor tabs/pucks have stabilizer in them as well. For every 10 ppm FC added by Trichlor, it also increases CYA by 6 ppm.
    mred's Avatar
    Sep 2008
    everywhere
    29
    well i checked my water today and my fc=3
    ph=8.0
    ta=240
    im a little out of wack here,any suggestions.
    30,000
    30,395
    Do you have a CYA test result?
    mred's Avatar
    Sep 2008
    everywhere
    29
    no,but i will assume its really high. sorry
    i would buy one of the kits off this board but i was laid off from work.
    the pool calculator has be a tad confused also.
    i guess i just dont need a pool
    30,000
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    ph=8.0
    ta=240
    You need to go to the pool store and have them test your CYA level. Once you know your CYA level, you will know your Shock level.
    Your PH and TA are too high.
    Read :
    How to Shock your Pool
    Defeating Algae
    How to Lower Total Alkalinity
    These articles are in Pool School. There's also an article on how to use the Pool Calculator, if you are confused at all about that.
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    Quote Originally Posted by frustratedpoolmom
    ph=8.0
    ta=240
    You need to go to the pool store and have them test your CYA level. (AND ASK THEM TO DOUBLE-CHECK THEIR RESULTS, STRESSING THAT YOU NEED TO BE REALLY SURE OF WHAT IT IS! I did this [and still on occasion] with Leslie's Pools and they have no problem double-checking their results for you! Cherie ) Once you know your CYA level, you will know your Shock level.
    Read :
    Defeating Algae
    32x16 buried Doughboy, 4' shallow - 7' deep
    Pentair Dynamo 1 hp, 2-speed - Pentair 150# SD40 w/zeolite (75#)
    One skimmer/two returns/Aquabot Turbo T2
    mred's Avatar
    Sep 2008
    everywhere
    29
    lowered my ph and the pool looks good. i will check first thing in the morning
    30,000
    mred's Avatar
    Sep 2008
    everywhere
    29
    well i had to go out of town and i come back and the pool has the yellow stuff again .
    30,000
    30,395
    Most likely because you chlorine is too low. Post test results and you'll get lots of help.
    mred's Avatar
    Sep 2008
    everywhere
    29
    thanks my girl friend dropped the ball for me, i gotta start all over and then leave out again on sunday
    30,000
    mred's Avatar
    Sep 2008
    everywhere
    29
    pool has been fixed sense the last time was on here,pool was just real low on chlorine and i had a pool light that had a leak and had rust in it.
    30,000
    Butterfly's Avatar
    South Carolina
    10,045
    Thanks for the update
    You're done SLAMing when:
