Thread: Hole in liner above water level
    ddpool's Avatar
    Jul 2008
    Well it happened....I discovered a small (1/2" diameter) hole in my liner. It is located just barely above water level (about 6" below top of pool) When kids are in pool the water does go over the hole. Do I need to be concerned? How would I fix this? Any tips/suggestions? Thanks.
    Coming Soon: In-Ground
    Previous: 24' Round AGP, 2HP Pump, Sand Filter, Solar Cover
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    Re: Hole in liner above water level
    You can get a vinyl liner repair/patch kit to fix it. Definitely take care of it. It will get bigger if left unattended, either by stretching or by curious kids poking about.
