Thread: HELLO FROM WAY UP NORTH...EH !!!!
    rentzie's Avatar
    Winnipeg, CANADA
    2
    Hi there...glad i found the post, cured my spring algea problem, now I am up and running...but not going to be a good year...need to replace my vinyl liner...i have a real old 16 x 36 rectangle inground TROJAN pool..prob bult 25-30 hrs ago...looking around $5K, if they dont have to cut out the concrete to replace the skimmer...(that would be another 1500.00..)OMG..!@! ...another problem is replacing the top coping (caping??)...it is the older 8" and i cant get it up here...any one know where i can get the white caping in the USA??? Keep up the good work...thanks...Jeff
    Way up North eh!!!...with old 16 x 36 TROJAN inground pool, sand filter, solar heat...need new liner....$$$$
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: HELLO FROM WAY UP NORTH...EH !!!!
    Welcome to TFP!
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    I suggest you post a thread in our "Under Construction" forum about the reno questions.
    You should get more help there
    You're done SLAMing when:
