Results 1 to 8 of 8
Thread: Pump
    Pump
    Have a 24,000 gallon pool what size horsepower pump do I need?
    24 ft round doughboy with deep end. Hayward pro series high-rate sand filtration system with a 1.5 hp hayward power-flo matrix pump.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Pump
    Do you already have a filter, if so what type and what size?
    Re: Pump
    Heywqard Sand filter Pro Series S210T
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pump
    Also, do you have anything that requires high flow rate, spa, waterfall, etc?
    If not, a 3/4 HP high efficiency pump should be more than enough. A 3/4 HP Whisperflo, will deliver about 70 GPM on an average pool plumbing system. That is about a 6 hour turnover which would allow for 4 turnovers a day. You might even consider a two speed and run on low most of the time to save some money.
    Mark
    Indiana
    4
    Re: Pump
    wow. ours is about a 24,000 gallon pool and we have a 2hp pump. Pool store said we had to have a min of 1 1/2hp. We went a little bigger.
    Above Ground Pool
    30ft Round X 54"
    Vinyl Liner
    Hayward 2hp EP1550LX Pump
    Hayward Swim Pro Series Sand Filter
    23,797 Gallons
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Pump
    ...yup 3/4n - 1hp hp is enough...you want your filter to be a little oversized if anything...sorry to break the bad news but with a 2hp you are probably just wasting money on electricity..unless you have a very long distance from you filter to the pool?
    The s210, is probably a little undersized for a 24k gallon pool
    Pool stores are notorious for pushing for bigger is better...just a marketing ploy, in reality even though the pump is capable of high flow rate...the piping and filter are not...again unless you have a long plumbing run, using 2"dia piping and an oversized filter
    11,969
    Re: Pump
    Any chance your 2hp is a 2 speed? You can run it on low to drastically reduce your elec bill.
    Indiana
    4
    Re: Pump
    No. its not a 2 speed. This is our second season with the pool and this may sound a little crazy but last year we ran the pump virtually 24/7 (yes I know didn't need to run that much, now we don't) but we didn't have this holy cow sticker shock of an electric bill through the summer. We are seeing the affects of running the pump all of the time though (bearing is making a little noise). Now we run about 5hrs a day. Our electric bill just wasn't anything to make you start to run around the house trying to find something to turn off.
    Above Ground Pool
    30ft Round X 54"
    Vinyl Liner
    23,797 Gallons
